Results 1 to 10 of 10
Thread: High idle when changing gears
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Default High idle when changing gears
    High guy's
    my daughter has a VS 97 series III commodore ute
    5 speed manual 3.8ltr and the thing revs it's tit's off between gear changes? so when changing gears it's doesn't return to idle unles you wait for revs to drop then change?
    any ideas guy's? i suspect TPS (throttle position sensor)
    I have cleaned IAC motor and throttle body.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Wouldn't be the 'power/econ' button on would it? With PWR on mine used to rev heaps before a gear change, but fine with it on econ.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by 2greedy View Post
    forgot to mention m8 it's a 5 speed manual no pwr/eco button
    Well theres that. Does it idle high when in Neatural?
    GothicKidd's Ride
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    no it idles normal in neutral and even if you rev it in neutral it seems to return to idle pretty quick, it's only when your driving and change gears it's reving like a mongrel! sounds like ya don't know how to drive and slipping the clutch?
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Ahh nuu, I can't help then I was going to suggest the idle adjustment thing on the TB but if it idles fine it's not that..
    Hope you get it sorted
    GothicKidd's Ride
    L67 Calais's Avatar
    L67 Calais is online now Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Similar thing happened to a mate and it was the speed sensor on the gearbox. Checked for error codes? Im betting it's that....
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Things I can think of are, sticky throttle or cable, The TPS is stuffed or you have a vacuum leak...
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by L67 Calais View Post
    If the VSS isn't working then the speedometer also won't be working. Does this problem happen all the time or only when the air conditioning is on (assuming the car has air conditioning)?
  1. vs - not changing gears
    By dags66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2011, 10:20 PM
  2. Hmm high idle.
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2009, 08:45 AM
  3. high idle
    By Got_Balls in forum V6 Development And Modification
    Last Post: 12-05-2008, 11:19 PM
  4. Very high idle
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 09:26 PM
  5. high idle??
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 11:52 PM
