Results 1 to 12 of 12
Thread: gas processors
    Dec 2007
    Default gas processors
    hi
    will the impco cdp-oz or commander fuel processor work with the impco l converter and 225 mixer
    thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Can't see how it will work as there is no fuel control with a mixer system, it's like a carby, put your foot down and in goes the fuel. Closed loop feedback from an O2 sensor won't make any difference to fuel delivery except with injection.
    Visit my Facebook page
    Dec 2007
    will the impco cdp-ox or commander ecu work with the impco l converter/225 mixer as theres impco cdp-oz or commander ecus on vr/vs v6 with the impco l converter and 225 mixer
    what works with the impco l converters and 225 mixers
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why don't you ask the people that sell them?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    the processor will work in conjunction with the 225 mixer and convertor when hooked up correctly , i dont have the diagram handy but once back at work should be able to find it for you and will post it up
    Dec 2007
    can anyone that knows about auto electrics put a ecu in a existing gas system that starts a car on petrol then automatically switches to gas.
    will a ds101 dual start fuel control work on a impco lpg
    someone with a gas license said you only need a license to work on the liquid side
    strgas's Avatar
    Oct 2009
    licenses are required to work on the high pressure side of the system correct , any other work can be performed by mechanics auto elec's , yet to here of anyone being busted for doing the work on the high pressure side without a license .
    Dec 2007
    strgas's Avatar
    Oct 2009
    correct but would you ask a plumber to fix your electric lights at home ? better to have someone that knows how to fit it and set it up correctly
    Dec 2007
    will it matter if anyone that knows about wiring harnesses and ecus works on the lpg electrical wiring and clear gauge
    strgas's Avatar
    Oct 2009
    only matters if they stuff it up and short out wiring and ecu's induce voltage where its not meant to be , use of scotch locks instead of soldering connections bad earths and dodgy connections , seen lots of poorly converted cars over the years in the trade .
    Dec 2007
    hi
    does anyone have a wiring diagram for the fcp-1 impco processor and will a impco cdp-oz work on a 225 mixer and e or l converter if a fcp-1 impco processor was there before
    where would you get a 2nd hand ds101 dual start fuel control and impco cdp-oz processor to
