Results 1 to 3 of 3
Thread: braking
    94 VR Commodore
    Dec 2011
    mount gambier
    Default braking
    hi all,, so my abs light is always on, when i brake my steering wheel wobbles, braking is fine tho... so my ? is how do i make the wobble go away and is it safe for me to dive with the light on still?????????????? any info would be great cheers
    <3 An Thats How I Roll <3
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could be one of many things with the ABS.....the wobble can mean you have worn steering or brake components. Any of these simply can make your car dangerous to drive unless you know that the fault will not affect braking, and from your post you are a bit unsure. My advice would be to get it checked over by either a mechanic or someone with some mechanical knowledge. If you have an accident caused or in any way related to the problems you mention you will not be covered by insurance, get booked....plus hurt, maim or even kill someone. Brakes are prime items.
    But apart from the lecture, even though the braking may seem fine right now, the ABS light and the wobble indicate there is something seriously wrong with the brakes....and they may totally fail at any moment.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I suggest you book your car into a brake specialists and get them to have a look at it before it causes further potentially dangerous issues.
  1. Braking point
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2011, 06:09 PM
  2. Braking problems
    By tonyrehe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 11:56 PM
  3. Engine braking
    By akust0m in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2008, 02:51 AM
  4. Braking Problem
    By MUNTED6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2007, 11:16 AM
  5. VT Jolts when braking...
    By chris239 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2005, 10:15 AM
