How does every one have there intercoolers mounted on there vs any pics of how its been done is much aprecated
Thanks scotty
this is with a 600x300x76 core (approximately 700mm wide with the end tanks, plus barbed pipe ends)
just l brackets up to the top radiator support and straight aluminium bar going to the lower radiator support
MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
Thanks for the pics helps alot iv had a go and its mounted pritty well iv included some pics of it
Same intercooler 600 x 300 x 76
a few things to note with what youve done. you might need to trim down the outsides of the top brackets to clear the headlights as they look pretty big brackets. and at the bottom. does it sit below the rail or equal?
a couple more pics
I havent done the bottom yet as it goes below where the radiator sits and i ether need longer brackets or i also thaught that i might bend the top brackets out wider than 90 degrees so the bottom is closer and would help with light clearance. Is the angle that the intercooler would be on from doing so cause any problams?
