Results 1 to 5 of 5
Thread: air conditioner compressor clutch
    vr ute
    Sep 2011
    beerwah
    Unhappy air conditioner compressor clutch
    my compressor started making rattling noises when the clutch on compressor kicked in .Looks like the rivets in the clutch are rs.can they just replace the clutch or do i need another compressor.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Being 16years old and not knowing it's condition prior to obtaining ur car, I suggest u get a fresh compressor. Should outlast ur time owning the car
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The front end of the compressor is easily replaceable....I'd get a compressor from a wreck and remove the clutch assembly after checking first that it was OK. Should be able to be replaced with the compressor in the car.
    This is the cheapest way - new comp is $450 plus regas $200 = $700 whilst comp from wrecker is $50 and no regas necessary but that is your choice.
    vr ute
    Sep 2011
    beerwah
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Got a VT one here for $50 if you can use that to either fix clutch and such or replace the VR one. In caloundra as well.
  1. VS Air Conditioner Condenser / Compressor issue ?
    By PrincessPeach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2011, 03:27 PM
  2. VX air conditioner compressor
    By asmith740 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2010, 06:40 AM
  3. Problem with Air Conditioner Compressor
    By tariq in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-09-2010, 07:06 AM
  4. Air conditioner compressor swap
    By nvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2009, 08:01 PM
  5. Air conditioner problem, compressor?
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2005, 11:12 PM
