Results 1 to 3 of 3
Thread: Hiding Wires/Pipes&Hoses
    20Reino00 is offline VS UTE
    Vs commodore ute 2000 seriesIII
    Mar 2010
    Post Hiding Wires/Pipes&Hoses
    So You open up the engine bay and there is S#!T everywhere looking at it gets on my nerves any ideas on de-cluttering/hiding wires/pipes and hoses would be great. CHEERS
    VS S-Pack SII
    May 2008
    - If you're happy to live without A/C... remove the condensor and compressor...
    - If you can solder wires well enough, relocate your coil pack and DFI module... (suggestion maybe the passenger side firewall??)
    - relocate the battery to the boot with a battery reloction kit (Mount it SECURELY in a vented battery box)
    - if you can get brake lines made up (Solid tubing type) you can move your ABS module to a similar location as where the DFI module could go? (May require engineering approval as you're playing with brakes???)
    - remove the plastic engine cover, cut the 4x threaded studs off the top of the plenum and polish the whole plenum/lid assembly
    - swap over the shitty looking plastic ducting that goes from the throttle body to the MAF and then to the airbox for some nice looking silicone hosing
    - install a strut brace (Aesthetic and better for handling... as ive heard the VS commodore's strut towers can move a bit in hard cornering)
    - get a chrome pulley kit (Water pump, harmonic balancer, alternator, etc)
    - chrome rocker covers
    - maybe re-plumb your power steering reservor to a different location away from the radiator... and a different reservor... polished alloy?
    Thats all i can come up with for now.... should get your creative juices flowing....
    Mar 2010
    Cheers i had already removed the plastic engine cover. so far i heve relocated and changed the coolant reservoir which looks much better, I also want to put on chrome pulleys and rocker covers just having trouble finding them. also would like to relocate a few things but i am a no hoper with anything electriacal especially soldering, so i might get an auto spark to do that work and ill stick to the mechanics something i have no trouble with haha... Also strut braces where can you find them ??? Thanks a heap for the help and ideas
  1. vr v6 master cylinder steel hoses to abs module where tyo buy replacement hoses
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2011, 10:56 PM
  2. Hiding wires from gauges on a pillar??
    By slappedvr in forum V6 Development And Modification
    Last Post: 23-06-2010, 09:58 PM
  3. [VR V6] replacing all radaitor hoses, power steering hoses, etc need help
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 08:40 PM
  4. Rear speaker wires hiding
    By azzfox in forum Car Audio
    Last Post: 28-03-2009, 06:42 PM
  5. Fuel Tank pipes, hoses...
    By Knud in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 10:32 PM
