I have a vs v6 ute that is running rough under load, motor flutters and sometimes misfires. This only started after running the fuel low (under quarter). I have replaced the tank fuel pump, cleaned tank and changed filters with no result. The problem does come and go. Whats next?
Welcome to the forum
a search woul yield a heap of info on this very topic, very common with the ecotecs, u just need to replace ur plugs and leads!
Check and make sure all the leads are plugged in. One of them fell off in my Vs and it ran like shit I found it haha But yes search it your best friend
This happened to me. It turned out to be the injectors, so I suggest you check them.
Hey mate I had the same problem a few months back, most likely your coilpack one or more will be shot. Try checking them,
Have your car running and get pliers so you don't get a shock, and pull the leads off the top of the coilpacks one by one, they should arc out, if ones shot it won't do anything,
Good luck brother
