Results 1 to 4 of 4
Thread: Signs on flat remote battery?
    GothicKidd's Avatar
    GothicKidd is online now ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default Signs on flat remote battery?
    Recently I've had to start the car by locking and unlocking the before it would crank. I've had the car for over 2 years now and never had to do this; It has only not started like this like 10 times, just needed to remove key and try again. but not this time.
    I was thinking of getting a new key because mine case is starting to pry apart, key head is loose and screws wont tighten and the button is stuffed (and i got a replacement one)
    So am I needing to get a new key or is it something else making this happen?
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    sounds like your key is a likely suspect. Does the remote work or not ? Thats 1 good indication the battery is dead.
    Also you will find a thin piece of metal ( or 2 ) around the ignition key hole. They are key-readers and must make good contact with the little bump on the key body beside the blade. You can gently bend them out a little if you think they are not contacting. I think only 1 works at any time, just depends which way you insert the key thats why there are 2 on the ignition.
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by greenacc View Post
    It works fine; Cant tell you if it works perfectly because button isnt fitted properly. but unlocks and locks just fine.
    Yeh, I tried pushing the key in harder to get a better contact but no luck. Ill try bending them out a little. I have 2 yeah, Ive also tried putting key in backwards but still nothing; Gotta unlock/lock.
    but ill try bending the contacts out and ill check out the plug on it aswell just to make sure. cheers
    GothicKidd's Ride
    greenacc's Avatar
    VE Berlina
    Jul 2008
    1 end is loose and the other is fixed ..... so bend from the loose end (lol )
  1. Battery flat in car, possibly in remote too?
    By Chev_350 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2011, 07:55 PM
  2. Flat Battery
    By Ronaldw in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-01-2011, 08:06 PM
  3. flat battery, how do i get in?
    By 2LOUD2OLD in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2011, 01:57 PM
  4. Flat Battery
    By ciddyau in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2010, 06:39 PM
  5. battery keeps going flat???
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2008, 01:22 PM
