Results 1 to 7 of 7
Thread: major light issues!
    Pearl White VS Calais S2
    Nov 2011
    Default major light issues!
    hey guys when i turn my headlights on, all the lights on my dash and lcds turn off, if i open my glovebox or turn my foglight on...my aircon turns on!? hasnt anyone ever had this issue before? im at whits end..ive replaced all the fuses in the fusebox
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by XCLSIV View Post
    Because that will fix it.....
    Sounds like you might have a grounding issue somewhere. Grab a circuit diagram and go from there.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Think back to what you did to the car before this happened - did you have the dash out...or maybe played with some electrical component.....the answer will lie there.
    Nov 2011
    ended up being fuse #1 under the steering column...cant believe 1 fuse can make the car play up sooo badly. btw the car wasnt touched..was just driving along..went to turn the lights on and bam!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Fuses do not blow for no reason! I'd try and track down why it blew before it happens again at midnite in a bad part of town when it raining and you have no torch...
    Pulling that fuse should not cause the problems you reported so there must be something dodgy there.
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by hako View Post
    oh no, it will. fuse 1 is a main power feed. if this isn't live, things start earthing back via other things in that circuit.
    Nov 2011
    yer fuse #1 is a big issue....
  1. Major battery drain issues (last hope)
    By molonator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2011, 09:56 PM
  2. major issues starting
    By too jazzy in forum General
    Last Post: 20-04-2010, 05:27 PM
  3. abs light issues
    By SV62NV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 08:00 AM
  4. Major VN issues
    By vsiicalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2008, 09:04 PM
  5. Major Security Issues With Php-nuke
    By VooDoo in forum Site Feedback / Site Problems
    Last Post: 08-02-2004, 11:15 PM
