Results 1 to 8 of 8
Thread: dash unit
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    Default dash unit
    Hi, does anyone know if you can install a digi dash from a vs or above into a 94 vr v6 auto? just curious and if i can ill get one instead of fiddling with the lil cog in my original dash
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    needs to be from a VR V6 for a straight swap over.
    but you will still need the forth plug, and splice it into the existing wiring.
    Oct 2011
    VS V8 Ute
    Jul 2010
    no digital dash for the VR/VS - I assume by digital you are referring to something like what the VK Calais had?
    Level 3 dash is available which gives you a trip computer, fuel used, average k's per 100k's etc etc (you will need the trip computer seperately to the cluster). Do a search - there's heaps on it
    Cheers T_C
    Oct 2011
    VZ Custom 3.6L Alloytec, VS Ute 3.8L Ecotec
    Nov 2008
    Darwin
    there is a level 3 cluster for the VS(unsure if VR had one) that had LCD displays on it. Requires a patch lead to be made up for the LCDs to work. talk to '88GreenVN' he helped me with this topic a few days ago
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Search "tripin" it will show what needs to be done to splice in a "4th" plug to the L3 cluster.
    The L3 gauges will work without a problem (same wires) but the "digital" part needs the 4th plug and a switch control to be wired in (patchloom)
    and 3 Dangerous non ABS VN's
    Oct 2011
    ok. jus one more question. does the vr ecu or whatever comp it is, does it actually record the odo? and will it show all the info im looking for? like overspeed on the dash, fuel usage, trip comp, that kinda thing?
  1. Replies: 6
    Last Post: 08-08-2011, 08:47 PM
  2. [WA] WTB VS L3 Climate Unit, A/C Comp, Dash fascia, Ashtray and more
    By Z2TT in forum Swap / Wanted to Buy / Trade
    Last Post: 08-09-2010, 02:34 AM
  3. Removed original head unit and now my Dash glovebox or rear lights work help please!
    By Jordzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2010, 04:01 PM
  4. VE Calais Head Unit / Dash Lights
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-09-2007, 02:53 PM
  5. dash top storage unit question
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-02-2007, 08:01 AM
