Results 1 to 4 of 4
Thread: Replace rear bump stops
    2000 VS III V6 ute
    Jan 2012
    Kapooka NSW
    Default Replace rear bump stops
    I intend to replace the rear bump stops on my 2000 VS ute. The driver side stop is nearly torn off.
    Is there any handy hints to make removal hassle free!! all suggestions welcome.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    is ur ute IRS or live axle?
    if its IRS remove the handbrake as it holds up the rear end, which will make life hard to remove the springs to swap the bump stops.
    but it should be easy enough
    ve sv6
    Aug 2010
    the vg-vs ute bumpstops are help in place with a retaining plate and 3 13mm retaining bolts that bolt to the chassis, undo the bolts and take off the bumpstop/retaining plate and the bumpstop pushes out of the retaining plate and you push a new one in and bolt it back up. if its lowered you can get shortened bumpstops from pedders, nolathane, whiteline and superpro.
    2000 VS III V6 ute
    Jan 2012
    Kapooka NSW
    Quote Originally Posted by ephect View Post
    Thanks for suggestions guys, I will give a go on the week end. Axle is live.
  1. Bump stops
    By SP00KSTER in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2011, 05:58 AM
  2. Bump stops
    By ranga101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 08:06 PM
  3. vs ute and wagon rear bump stops.
    By old mate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2009, 05:34 PM
  4. bump stops vs ute
    By vs-s-pak-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 01:07 PM
  5. Bump Stops?
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 07:38 PM
