Results 1 to 5 of 5
Thread: cutting pink wire and re-earthing o2 sensors vs commodore?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default cutting pink wire and re-earthing o2 sensors vs commodore?
    hi what would happen if i was to cut the pink wire and cut and redo the eath to a different part of the block on a vs commodore v6 with 4 wire o2 sensors? ive re earthed the ecu earth but was reading allot about the pink wire and re earthing them at the sensor
    like would it stuff things up? where they earth at the moment the earthing points dont look to good and the connection looks like it could do with an upgrade/replacement
    cheers
    96 VS Series2
    Jul 2011
    How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    try this link not sure if it worked but it on the main page in "commodore how to" i was just reading it and seems a better way of doing it rather than cutting wires.
    will be doing it myself.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    once u cut the pink wire there will be no heater circuit..
    dont know if u've read throw my how-to as you've meantioned u re-rearthed the ecu earth; is that
    a) the earth for the ecu only or
    b) the earth at the ecu for the o2 heater curuit?
    edit: Jman_83 bet me to it!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My opinion only, but why bother to cut the wire etc if you were having no problems before.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh i redid the earth at the ecu as mentioned ine your post ephect
    reason i ask is holden used a non heated o2 sensor in the vn vp etc then vs they used a heated sensor then in vt vx vy and so on they used a non heated sensor again as they had issures with the heated ones, was just thinking of cutting it for good measures and at the same time redo the earths as maybe it might help? , but then again im just looking for things to experiment with lol
    cheers
  1. vs oxygen 'pink" wire help
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2009, 06:31 PM
  2. cutting wire? 6x9s
    By callum_88 in forum Electrical Wiring / Questions
    Last Post: 05-03-2009, 02:48 AM
  3. Earthing off your ecotec O2 sensors
    By cxcxcxvcvcvc in forum Holden Commodore How-To's
    Last Post: 10-02-2009, 02:41 PM
  4. Pink wire on O2 sensor?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2008, 08:15 PM
  5. moving earthing wire ??
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2005, 09:32 PM
