Results 1 to 20 of 20
Thread: vr v6 running rough
    94 VR SERIES 2 ACCLAIM
    Aug 2011
    clermont
    Unhappy vr v6 running rough
    hi every one im new to this great site and your help would be great
    I just brought a VR V6 commadore and it is running rich and rough. I noticed
    on the extractors there is a O2 sensor and it is not connected and it has only 1
    purple wire. Would this be the right sensor for a VR and if it is where does it connect to?
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    I think you have answered your own question, without the O2 sensor your car will stay in closed loop making it run rich. as for the wiring pass. I have a vs.
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Jonah 101 View Post
    I think you mean open loop. When in closed loop the ECU is using the o2 sensor readings to adjust the fuel trims.
    St3alth187's Avatar
    St3alth187 is offline More time than money
    VR Calais 3.8L Manual
    May 2011
    Nyngan, NSW, Australia
    Definitely sounds like a O2 Sensor problem.
    First of all check error codes following these instructions:
    Checking error codes VR/VS (Revised)
    For the VR i was aware that the O2 sensor is located just before the Cat Converter. These are 4 wire Oxygen sensors as they have a heating capability.
    The location of the O2 sensor you described is not operating at all, the two wire O2 sensors i thought were on VS models and up.
    There should be two, one on each header/extractor.
    Cheers,
    Jake.
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Quote Originally Posted by Brett_jjj View Post
    I think you mean open loop. Closed loop is when the ECU is using the o2 sensor readings to adjust the fuel trims.
    Lol Thanks its late
    Aug 2011
    clermont
    vs commodore
    Oct 2009
    Tamworth NSW
    Code 13 is oxygen sensor (open circuit). I always thought that the VSV6 was the first to use the 4 wire heated 02 sensors and use 2 sensors,one in either engine pipe, and that the VRV6 used 1 sensor and are the 2 wire type.
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Are you sure your car is a VR? there are subtle differences between the two.
    Aug 2011
    clermont
    vr it is, runs like shit will see if i can find the o2 sensor near the cat converter
    Aug 2011
    clermont
    with the error code 13(open circuit) what does that mean,do i just replace the sensor
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    my car is a vr series 2 acclaim. having similar problems but thats not y im writing. just wanted to clear up one thing. the vr i have has the single o2 sensor just before the cat. and it has 4 wires not 2. i believe it has 3 the same color (grey i think) and one different. IMO that is
    VS Acclaim
    Jul 2011
    NSW
    Most vs's had 4 wire, very early ones had two wire.
    Most vr's had 2 wire, late ones had 4 wire.
    Oct 2011
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    I just had a look at the wiring diagram in the VR gregories workshop manual,and it shows that the VR uses the 4 wire type oxygen sensor. Theres 1 Pink/blue wire, 1 Violet wire, and 2 Black wires coming from the sensor accoding to the diagram..Theres no mention of the VR using a 2 wire oxygen sensor.Usually the gregories manuals have a supplement section at the back that will show any alternative diagrams or parts changes etc to account for any changes made during the model life.
    I just always assumed that the VR used the same 2 wire sensors as the VN and VP's.
  16. #16
    VN
    Oct 2011
    your house
    Quote Originally Posted by Robb View Post
    Why did late VR's have a 4 wire, while early VS had 2?
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    The only explaination I can really think of is that oxygen sensors have to get to a certain temperature before they work, so they used 2 wire non heated type sensors,( which are probably cheaper), and moved these sensors location closer to the engine on the VS, which in theory, should make the sensors heat up faster and start working quicker, they also added the second sensor to the opposite exhaust pipe on the VS, maybe they thought they wouldnt have to run the heated sensors with these changes theyd made, then they later found out that the non heated type didnt work properly, and the heated ones were needed afterall ,so they went back to the heated type 4 wire ones again.
  18. #18
    VN
    Oct 2011
    your house
    vs commodore
    Oct 2009
    Tamworth NSW
    The first VS's definitely had 2 wire type, and then they went back to the 4 wire type. The 2 wire VR ones though, I cant find anything about them, just the 4 wire ones. .
  20. #20
    Dec 2009
    VN's had one black wire going to their O2 sensor until November 1990 when a tan earth wire was added. The sensor I replaced in my 10/1990 V6 had one black wire, the sensor earthing through the exhaust system. Got this info from a Gregory's manual for a VN.
  1. Running rough as, running hot..Ideas?
    By Maxxiz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2010, 11:29 PM
  2. vt rough running
    By Jaybee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:37 PM
  3. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  4. VQ Running rough
    By simon0081 in forum Electrical Wiring / Questions
    Last Post: 12-02-2009, 07:52 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
