Results 1 to 9 of 9
Thread: Changing fuel reg. VS
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Default Changing fuel reg. VS
    Hey guys, im stuck at the moment. Went to go do my fuel reg this morning and hit a wall. I dont want to break anything so i thought i might ask as i need my car for work tonight.
    The problem i can see is the hose "appears" to be stuck to the fuel pressure reg. Any ideas on how to remove it? Picture attached. There appears to be a plastic line inside of the rubber one that is pretty well attached to the barb.
    Cheers.
    VS
    Jul 2010
    Just went to Holden to get a price on them changing the reg on the hose, they reckon they cant do it.. Im lost.
    St3alth187's Avatar
    St3alth187 is offline More time than money
    VR Calais 3.8L Manual
    May 2011
    Nyngan, NSW, Australia
    Just put it in a vice and give it a pull mate. If the hose breaks it should still be long enough.
    If not just take her down to your local radiator joint, they should have some hose in stock.
    Cheers,
    Jake.
    vs ss
    Dec 2010
    Just cut the hose off with a razor blade.. cut it parallel with the barb and just fold it off
    VS
    Jul 2010
    Thanks for the tip guys, i got it off using some heat treatment. Will write up a how to on how i did it.
    VS Berlina/ KJ Verada
    Sep 2006
    How much was the regulator and where did u get it from?
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VS
    Jul 2010
    Dec 2009
    "If not just take her down to your local radiator joint, they should have some hose in stock".
    Shouldn't it be fuel hoes not radiator hose?
    St3alth187's Avatar
    May 2011
    My local radiator joint stocks hoses for all applications.
    If a country radiator shop does that I see no reason why anyone else shouldn't.
    Cheers,
    Jake
  1. Fuel sender, after changing fuel pump. Question that has not been answered.
    By seq4x4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2011, 03:24 PM
  2. Changing from gas to fuel
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2009, 07:20 AM
  3. Changing from Gas to Fuel. What to do?
    By greenvs in forum General
    Last Post: 04-02-2009, 09:18 PM
  4. Changing Fuel Filter Plz Help
    By Mic 'n' son in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2006, 01:47 AM
  5. changing fuel
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 10:48 PM
