Results 1 to 2 of 2
Thread: VS auto trans isse
    VS executive 3.8
    Oct 2010
    narre warre south
    Default VS auto trans isse
    Hey fellow commodore owners i was hoping u could identify a problem im having with vs v6 auto and to fix it. When im driving at aprox 60 to 70km and then slow to take a corner, as i try n exit the corner it feels like tranny is changing back in 2nd but instead is holding third or forth. When i do accelrate from the corner the tranny seems to slip then goes into 2nd then shifts as normal when i drive off
    To me its seems lift a shift solinoid or something like that. No errors have come and the car runs perfect and is always serviced and maintained (by myself) if it is a shit solinoid is it a diy job i could do? And how much would a solinoid actually cost? Open to any interpretations
    Cheers everyone
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it was a solenoid gone bad it should show up in an error check. I'd also check the fluid level when hot. Maybe also check the TPS.
    Checking error codes VR/VS (Revised)
  1. Auto Trans Sport Button, What Auto models have it
    By Zerone_V in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-09-2011, 05:50 AM
  2. [SA] WTB: VN VP V8 Auto Trans
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 18-04-2010, 02:29 PM
  3. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  4. [SA] F.S. 96 VS v6 AUTO TRANS low km
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 10-09-2009, 09:29 PM
  5. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
