Results 1 to 4 of 4
Thread: auto
    lil_matty89 is offline Living Life Low
    VS Calais
    Oct 2011
    Mount Waverley
    Default auto
    auto 1995 vs calais with a 6hdd auto in it does this mean a 7hdd will fit
    Lil Matty
    VS Calais
    Oct 2011
    Mount Waverley
    the only reason i ask is because i have been told that 5hdd 6hdd and 7hdd arent the same. and then others have told me it will fit. i have a 7hdd just sitting there untill i am 100 percent sure it will fit and work before pulling my 6hdd out
    Lil Matty
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Itll Fit.. My car came with a 7HDD, I not have a 6HDD in it. The difference is the lines, youll need to change the line adapters over on the boxes to make it work.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I believe the 6hdd is series 1 and the 7 hdd is series 2.
    Series 2 VS had an upgrade to the valve body. IIRC to do with the oil passage and control solenoid to the converter clutch.
    As above, it will fit.
  1. Auto Trans Sport Button, What Auto models have it
    By Zerone_V in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-09-2011, 05:50 AM
  2. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  3. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
