Results 1 to 6 of 6
Thread: turbo 5lt vs statesman
    vs stato
    Nov 2011
    darwin
    Default turbo 5lt vs statesman
    Im turboing my vs statesman and im sorta following a fourm post from a guy who did it.
    Now im having trouble with a place to put the alternator,
    Is there another way to run the power stearing pump? Electric maby so i can get rid of the stock one?? This would be a sutable solution if it is do able ?
    Photo of my white stato and one of the guy im copying.
    Attached Thumbnails Attached Thumbnails turbo 5lt vs statesman-image.jpg   turbo 5lt vs statesman-image.jpg
    vs ss
    Dec 2010
    vs stato
    Nov 2011
    darwin
    Default 5lt turbo
    I have lost the air con all ready for headers to be turned around and doing the same on the other side other wise there is no room for the dump pipe due to the rails pictured
    vs ss
    Dec 2010
    You don't have to face the drivers header forward, you can either run the crossover around the back of the engine or use a short radius 90 at the flange and go forward that's how I did it ad I still run my a/c in the factory spot, you won't fit a big enough dump trying to squeeze past the chassis rail, just run it behind the strut tower and cut a hole there is nothing structurally wrong in doing so. You really want a 3.5" dump minimum.
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Got any better pics of it installed so we could get an idea of the room. Even a pic from directly of the engine left and right hand side.
    vs stato
    Nov 2011
    darwin
    Default 5lt turbo
    Do u have any pics of your set up? How can i find what is structural and what can be cut? The plan is to have both headers push forward into the turbo but im open to sajestions? There isnt much room.
  1. [QLD] V6 turbo parts, turbo kit, fuel system, zorst, intercooler
    By harro_VR in forum Parts And Other Items For Sale
    Last Post: 05-04-2011, 11:51 PM
  2. [SA] vl turbo motor/trans/microtech/fmic/gtr/plenum/turbo + vs v8 5spd conversion
    By nasty1 in forum Parts And Other Items For Sale
    Last Post: 18-05-2010, 07:58 PM
  3. wk statesman turbo heat problems
    By wkstato in forum General Discussion
    Last Post: 04-12-2009, 08:39 PM
  4. FS: VS Series 3 Caprice Statesman TURBO Immac! $20,000
    By HIROLLA in forum Vehicles For Sale
    Last Post: 14-10-2008, 12:13 AM
