Okay, so I have read "some" (I am not going to claim all, that would be a lie :P) of the Code 31 threads but none of them really apply to me, unless, of course, the one I overlooked had the information in there. Has anybody ever experienced a code 31 followed by complete sluggish-ness of their car?
I have been getting the code for 2 days now and every time I get it, my car performs like it's in LHM until I turn it off. I have a paper clip with me in my car at all times (You get used to having to need one) and I always test when I get a CEL.. The LHM code never appears but the 31 for the stupid TD signal missing one always shows up.
Anybody keen to shed some light as to why this would be happening?
have you tried resetting yur ecu? and what are your revs like once you get going? try taking off in LOW and see if the takeoff imporves.
Yup, I've tried. Doesn't seem to work. The code just comes back (Always while I am idling through a car park though or at lights, etc). The Revs are fine once I get moving but I can still feel some sort of resistance to my prompts on the throttle. Usually the response is almost instant (Not with acceleration, the car is old so I don't expect much) but the revs usually rise straight away even with slight movement on the pedal, but not while this code is appearing.
what i ment is like does it still change thru gears? if its in limp home mode then it used one gear(second i think) and sticks with it, when you get up to about 70 how high is your taco reading?
The gears operate as normal, it's just initial take off and general acceleration that is being affected. Which is why it's confusing me so much :\
yea me to. can you manually take off in first using the t-bar at all?
Next time it happens I will try and let you know. If anybody else has any other info on this, I would appreciate your help too.
could be your 1-2 selanoid. ive seen a few posts on here about sluggish takeoff. ill try and find one for ya
The box was reco'd not long ago. It wouldn't surprise me if something has stuffed up already, though.
yea these things do happen. i myself have just replaced my trans with a recon one because mine died in the ass. reverse was ruined and wouldnt engage and it locked itself in either 1st or 2nd. that ment i was doing 70ks at 4500RPM lol. it took me 3 weeks to change over by my self and boy was that hard. now i just have these stupid sensor and CEL codes to deal with
Is your remote working? Have you tried to use your spare remote/key (assuming you have one).
