Results 1 to 7 of 7
Thread: ABS Problems
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Default ABS Problems
    Ok, ever since i put in my new throttle body and reset the computer the ABS light has been on. Did some searching on the ALDL error codes and i am getting 12 (Reading Properly) and 27 (Front left continuity fault).
    A couple of weeks before hand i did replace the front left wheel hub with a brand new one. I dont recall removing any wiring.
    Any suggestions on where i should be looking or what i should be doing?
    Car of course is a 96 S2 VS
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds as though you may have fitted a non ABS hub.
    Visit my Facebook page
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    there would have to be a sensor there otherwise it cant tell if the wheel is locked up or not. my vr has disks on all four wheels that have slots in them where the sensor reads much like the notches in the back of the harmonic balancer for the Crank angle sensor. have a look at your old one to see it it has anything like what i described.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    [QUOTE=Not_An_Abba_Fan;2089257]Sounds as though you may have fitted a non ABS hub.[/QUOTE
    I think you right.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    If you have ABS you must have disconnected the wiring from the hub when you were taking it off, so you should have a wire dangling from the suspension strut. The colour of an ABS hub for IRS rear suspension is grey (OEM part no. 92039932), for five link rear suspension it's black (OEM part number 92033919), and for non-ABS some other colour (OEM part no. 92046941). After market IRS/ABS hubs I have purchased have followed this colour code.
    Zarconia's Avatar
    Aug 2010
    Rockhampton
    I definitely asked for an ABS Hub. But i may have been supplied an incorrect part not certain.
    Looking at the back of the hub there are only 2 tubes. One for the brake and the other i assume is for the abs which i didn't remove when i replaced the hub.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    The abs system will perform two checks when the igition is turned on.
    One is a continuity check to ensure there is no open circuit in the wiring or sensor coil.
    The other is a signal check (above 5kph IIRC) to ensure the ABS module is recieving a signal.
    I would say there is a wiring fault.
    Unplug the offending sensor and connect it to a digital voltmeter set on A/C volts.
    When you spin the wheel, the meter should show a reading.
    If not, set the meter to ohms and check there is no open circuit.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. few vx problems
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2009, 08:16 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
