Results 1 to 4 of 4
Thread: V6 engine spazzes out on both LPG and petrol (intermittently)
    VSII Ute
    Feb 2010
    WA
    Unhappy V6 engine spazzes out on both LPG and petrol (intermittently)
    The last few days I have experienced a loss of power on LPG. When this happened, I hear buzzing from the LPG controller.
    It sounds like a relay switching on and off rapidly. So obviously I switch to petrol. But when I do, it idles about 1500 RPM,
    until the aircon compressor engages, then it nearly stalls. It then seems the compressor cuts out, and engine revs up to
    1500 RPM again. Also seems to lack power with petrol: can barely reach 90 km/h with pedal flat to the floor.
    Still sounds smooth though, not like any cylinder is misfiring.
    Next morning, it starts okay, and has full power, but after an hour or so, starts playing silly buggers again. So something is
    screwing both petrol and LPG. I checked the PCM error codes - nothing but 12. I had a good look around, air intake is
    okay, and can't see loose wiring or vacuum hoses.
    Any suggestions?
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    VSII Ute
    Feb 2010
    WA
    Quote Originally Posted by aussie4life11 View Post
    maybe your TPS or your o2 sensor are on their way out.
    You could be on the right track. Since yesterday, it won't run at all on LPG. I unplugged the LPG contoller
    and it has since been okay on petrol. This unit (AEB) uses only TPS, exhaust oxygen sensor and
    ignition pulse (RPM) as inputs (plus a few on/off signals like aircon compressor). I think the AEB black
    box has died, and also corrupted either the TPS or exhaust signals, so the PCM is befuddled.
    Oct 2011
    has your engine light come on at all? even if it hasnt have you checked your CEL codes?
  1. Engine cut-out on petrol around 3000rpm
    By vscalais995 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2012, 11:40 PM
  2. Engine light coming on intermittently on vn s v6
    By Launer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2011, 09:15 PM
  3. '92 VP ute problems, gas and petrol, engine light, cutting out, choppy acceleration.
    By Burky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2011, 12:46 PM
  4. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  5. Engine leaking petrol when not running?
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 05:24 PM
