D
drewzle
Guest
Hi,
I have a 1993 VR Berlina, I have had an aftermarket Immobiliser put in the car about 2 years ago. With the two sets of keys that I have, one works fine at the other doesn't.
What happens with the remote is, using the aftermarket remote, it unlocks the door and turns off the immobiliser, you put the key in and turn it and the car does not start, switch it back to off again and then onto start (in some cases you have to do this three or four times) there have been other cases where you need to keep pressing the button to unlock and lock the door and switch the ignition to start and the car kicks over.
If you do this with the Buttons on the Holden key facing towards the windscreen (in the off position) it has this problem, switch it over so that logo is facing the windscreen it starts up straight away.
I took the car to the guy at Alberts where the Aftermarket Immobiliser was installed and he believes that the Remote that comes with the car is causing a problem with the Aftermarket Remote and Immoblisier.
This only happens with one set of the keys, the other is fine, has anyone else seen this issue before ?
