hi i found this and was wondering how it works and how i could make one of my own if it actually does work? or is it just a scam and you really shouldnt do it?
Increase the Voltage on your Car by 0.5-0.8 volts depending on electrical loadand engine rpm. Good for those with Big Stereos or High Wattage Lights which place extra strain on the Altenator and Battery. This Voltage Increase Kit will Boost ...
cheers
you wouldnt need it unless your constantly coming out to a flat battery really IMO
Load of shit. Volt's isn't what you want anyway.
and 0.3 of a volt is miniscule. did sum1 say ripoff?
massive ripoff when it is just a single diode that cost less than a dollar in the voltage sense wire.
can't hurt to do it, half a volt can make quite a difference under load.
but u dont want volts, u want amperage. amps are the more important thing in electricity. its y ppl can be struck by lightening and still survive. u can be zapped by a trillion volts of electricity and as long as the amps are below 0.33A or 33 milliamps you can survive. thats all it takes 0.33 of an amp. crazy huh
thanks wraith. comes from studying electrotechnology at tafe lol. but im suprised i can still remember it as it was 7 yrs ago now lol
btw wraith love ya avatar pic lol
do i remember correctly you times volts by amps to get watts? like this (amps x volts = watts)??? lol
Ohms law? lol
My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
omg, dont test me like that. its to long ago lmfao
that would be ok until someone got out as the pool is an insulator being made outa plastic/rubber. but bravo to the white stupidity
ohms law is I(current) = v(volts) / R(resistance or ohms). lol. joys of google
love the waterproof cord on the edge of the pool hahaha
If you have a big system, could you not just use a capacitor?
I meant it like TAFE lol
oh ok. wat did ya study den?
Dr. 304, capacitors regulate the current running through them. it means that with a capacitor you have a discharge rate and instead of the fluctuations you would get when turning on and off things in your car eg headlights, subs, you would get a constant current. it helps prevent damage. it can also be used if you experience whining through your stereo system to stop it as the whining is the fluctuations.
did mine in gero. cert 1 in electrotech, second semester 2005 lol
