Hi
I think I have my leads wrong anyne know the order?
1 6 5 4 3 2 is the firing order
No1 is the front passenger side
1 3 5 are on the passenger side
2 4 6 drivers side
Front
1 2
3 4
5 6
Back
if it has the 3 coil packs like mine it is all electronically controlled. the only thing you can do wrong is to put the wrong leads on the wrong plugs. i will find you a image of the plug order
Ok thanks heaps
Ok this might sound stupid but can you type it as coil pack number to plug number (c1 to p5) thanks
Errr...... C1 to P1, C2 to P2 etc etc etc. Coil number must match the lead numbers as posted in the image above.
MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
i believe they go as numbered, c1 to p1 and so on and so forth. as its electronically controlled the ecu selects the firing order
