your thinkin oh no not him again lol soz ppl its tru. i wanna upgrade my dash to lvl 3. i am aware of many many how-to's and posts on the topic. thats not y im here.
im here to ask if i would need to do the rewiring for the extra harness in my 94 vr series 2 acclaim?
and also im looking at lvl 3 clusters on ebay and found this one. HOLDEN VR,VS CALAIS/HSV/COMMODORE-LEVEL 3 DIGITAL DASH/INSTRUMENT CLUSTER-V6 | eBay
what do ppl think? should i go for it?
Someone on here does the lvl 3 harness I'll find the thread
and also where does the trip computer controls plug into? the old speed alert connector or a new one off the lvl3 wiring harnes?
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
ok. so basically you take the 2 connectors off the lvl 3 harness and connect each wire to the same color one on the lvl 2 harness. am i right?
so 10 connections including the ecm one. thats easier than i thought
@seq4x4, looking at that diagram is that looking from the front or the bcak? and is connector 1 ont the left or the right?
undo the fuse cover panel under the steering wheel and look up to the right side roughly inline with the cluster, is the white connector there and not in use? you may be one of the lucky ones and not have to wire anything up
nope not there and there is only the 3 hazard/rear window/ ac harnesses + the overspeed alert harness. damn it
yea well i probably wouldnt have even thought to check lol. btw, i had an idea. i can use the dash harness off of the wrecker i go out the back to wire up and then without removing the original one from my car i can test if it works outa the car. lol am i a genius or wat? pmsl
When the harness is still in the dash, from the Left it goes 1 2 3.
Refer to the Tripin' thread, you'll get more info, Markovr (diagram) and 88greenvn (helpdesk) are the men!
been there
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
which connector cos i got your diagram from tripin and i think the other wire is ment to go to the harness in the ecu according to that. lol
my bad. just looked at it again. i was wrong
which is connecter yb62? is it labeled?
Its the yellow and black wire at the ECU. From memory theres only one..
here
