Results 1 to 8 of 8
Thread: having problems with my vs starting some times
    luv_mi_96_vs is offline Banned
    93 vr wagon
    Jan 2012
    dubbo
    Default having problems with my vs starting some times
    hi everyone, im new to the site so i hope im posting in the right place i have a 96 vs and recently it has devolped a problem and i was wondering if any one could help. some times when my car is idleing or slowing down it will cut out, i was thinking injector problem? and every now and again when ive been driving it for a while and turn it off park it and come and try to start it, it wont start. i then leave it for about 10 min and it then starts up so ive been thinking crank angle sensor could any one tell me if im wrong or right?
    thanks
    mitchel
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Give the CAS a go. Sounds like its that.
    Wierd prob with the slowing down thing..
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    few commodores
    Feb 2011
    victoria
    93 vr wagon
    Jan 2012
    dubbo
    i think its the crank angle sensor i had a mate that had a falcon do a similar thing and it was the sensor and as for cutting out when slowing down i did a little bit of research and what i come up with was that the crank angle sensor sends pulses to the injectors so if its not pulsing properly then the car will cut out?
    few commodores
    Feb 2011
    victoria
    it could well be, but i mentioned checking the codes (takes a few minutes) as it may not be that and you'll go through replacing it and still be having the same issue
    almost exactly the same as if you took it to a mechanic, first thing they'd do is hook a tech2 up to it and look for any red flags pointing out an issue.
    93 vr wagon
    Jan 2012
    dubbo
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    93 vr wagon
    Jan 2012
    dubbo
    ok cool thank you il try it tomorrow
  1. vs commodore at times seems to backfire when starting
    By James39 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2011, 08:00 PM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Problems starting a VK 3.3 EFI
    By 2_SeeK_U in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2007, 09:13 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VK Starting Problems
    By Boydi! in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2005, 02:06 PM
