Results 1 to 15 of 15
Thread: Recent mods cause...
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    Default Recent mods cause...
    Hi guys,
    This afternoon i fitted a MACE CAI and a 70mm TB.
    Straight after i started the car and all was fine, idling fine. I give the throttle a stab and it has a hiccup before revving up. When i say a hiccup it pauses for split second.
    The other thing was the engine light was on.
    I havent checked for error codes yet but what could i have missed? I sealed the TB to the manifold, even used loctite master gasket, connected the wiring and hoses...
    Im stumped!
    few commodores
    Feb 2011
    victoria
    check codes, i'm thinking tps, iac mayb vac leak as you've been playing with the tb, but no point speculating really till you have the codes read
    Jul 2010
    Wilton/Sydney
    i do know it will spit out a speedo code... speedo broke shortly after i bought the car. the last 12 months i have been driving round without one :P LOL!
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Its because of the larger TB. You will need to get your car tuned to suit it. Im betting your code will be low TPS voltage
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    Jul 2010
    Wilton/Sydney
    If that is the case, will it hurt anything or make things worse? should i just put the old TB back on until i order a tune?
    Jul 2010
    Wilton/Sydney
    Codes that were spat at me is 12 and 22.
    **L67 you were indeed correct, it is a low voltage TPS. Next questions is how can i fix this and will it affect my fuel economy and/or power? Will it hurt my engine until i get it fixed?
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Get a tune.. That'll fix it.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Jul 2010
    Wilton/Sydney
    Mar 2008
    Fenix_Longbow,
    Before considering any memcal upgrades, did you put the plastic sleeve on the end of the shaft on the throttle body for the TPS? Please refer to the instructions below if you're unsure
    http://www.maceengineering.com.au/We...TALLATION_.pdf
    90% of this time this is usually the problem
    Please keep us posted
    Cheers,
    Steve
    MACE Engineering Group
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    L67 Calais's Avatar
    Jul 2008
    Andrews Farm, SA
    Good point Steve.
    To the OP, If this isn't the case, Driving it under normal conditions should be ok although you may get some erratic idling intermittantly.
    I wouldn't recommend doing any WOT runs though just incase.
    A tune will fix all if Steve's idea isn't correct.
    Jul 2010
    Wilton/Sydney
    Wow... I swear to God my old TB didnt have this plastic sleeve... How annoying
    As usual, thanks for the prompt help Steve and my thanks to the rest of the JC for your help with this
    L67 Calais's Avatar
    Jul 2008
    Andrews Farm, SA
    Your old TB does have the plastec sleeve. Has it sorted your issue?
    Jul 2010
    Wilton/Sydney
    My old throttle body didnt have no. But i went to the wreckers and found one of these sleeves with a washer and spring aswell. Brought it back and went to put it on but it wont fit. The sleeve is the same size as the metal tab that you are supposed to slide it on.
    Im guessing that its down to the tune now?
    How much do MACE charge for a tune? And is there any cost difference between them and The1 or Delcowizard?
    Jul 2010
    Wilton/Sydney
    Just spoke to Steve, he is of the opinion that my TPS is shot Well will put my original one back on and will let you guys know if it fixes it. I just ordered a MACE memcal too so will also post up the results of this
  15. #15
    Jul 2010
    Wilton/Sydney
    Ok, it was a dodgey TPS. Replaced it with my old one everything is a-ok
    Thanks all for your help
  1. Recent power loss??
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2009, 12:30 AM
  2. My recent fine
    By VryNeat in forum The Pub
    Last Post: 19-03-2009, 11:51 AM
  3. Recent purchases
    By Bax in forum The Pub
    Last Post: 26-09-2008, 09:19 PM
  4. Recent ticking noise???
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2006, 08:02 PM
