Results 1 to 3 of 3
Thread: 96 VS V6 Commodore Acclaim shuddering intermittently
    1996 VS V6 Acclaim Sedan
    Jan 2012
    Wollongong
    Default 96 VS V6 Commodore Acclaim shuddering intermittently
    I have a VS Accliam with IRS and ABS which has done 198000km's. I had all the brake pads changed and hand brake adjusted. The hand brake appeared to be over adjusted by the mechanic and was dragging slightly. What the problem was was that it intermittently developed a shudder even at low speed. The whole car would shake. Even with car in neutral and rolling.When I stopped and started again driving it disappeared. Can this be caused by an over tight handbrake adjustment affecting the ABS? I had the hand brake readjusted and could now not bring this fault back up. I thought it may have been the centre bearing on the tailshaft but it appears too coincidental that it appearred the day after I had the brakes done. Has anyone else experienced something similar or can offer any ideas. The shaking was quiet excessive at even a low speed at 30k's. Any comments would be appreciated.Thanks
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    So..... The issue is now fixed after the adjustment?
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    1995 vs commodore
    Oct 2011
    bribie island
    mine did pretty much same thing problem was my leads were cross firing so got new ones ran like a dream
LinkBacks (?)
  1. 95 Commodore Acclaim
    By CyraxNZL in forum VR - VS
    Last Post: 30-10-2011, 02:16 PM
  2. My Vs Acclaim S1 commodore.
    By willz89 in forum VR - VS
    Last Post: 06-12-2008, 08:07 PM
  3. EBA and EBD vz commodore acclaim.
    By vinnycol in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-10-2008, 09:16 PM
  4. PROBLEMS VP COMMODORE V6 series II SHUDDERING AND STALLING
    By VEEPEERYDA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2008, 01:32 AM
  5. F/S 98 VT Commodore Acclaim
    By ScottB_33 in forum Parts And Other Items For Sale
    Last Post: 29-05-2006, 11:58 PM
