Results 1 to 4 of 4
Thread: Possible fuel problem
    95 VS Acclaim
    Jan 2012
    Default Possible fuel problem
    Recently replaced the fuel filter after a long trip Cairns to Adelaide, car was running on low revs no worries but struggling under accelaration. After new filter no worries. Has started doing the same thing. Checked fuel filter all good. Any suggestions, could it be the fuel pump that needs replacing?
    95 VS sedan
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    How did you check the fuel filter?....replacement is the only real way of checking.
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    I would check to see if the fuel filter is the wrong way round first... Could also be blocked injectors or bad fuel pump. I would try using a tank of 98 octane with injector cleaner and see how that goes after you check the filter.
    95 VS Acclaim
    Jan 2012
    Pulled the filter out and blew air through it, clean as a whistle. I'll check the coil packs in the morning then injectors after that
  1. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  2. fuel problem
    By brandon17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2010, 07:38 AM
  3. SV6 fuel problem????
    By BUSTER1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-06-2010, 05:37 PM
  4. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  5. Fuel Problem need help
    By Old Goldie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-01-2006, 07:18 PM
