Results 1 to 14 of 14
Thread: Trans help
    Vs Berlina Series 2
    Jun 2010
    Default Trans help
    Who knows if a vn/ vp trans will fit into a series 2 VS berlina ??
    if not what other trans will fit in ? eg vs statesman ?
    VS
    Jul 2010
    Sunshine Coast, Queensland
    No. You can get a 6HDD, 7HDD and if you want a stronger box that needs a little work to make fit, 9HFD.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You need the specific transmission for your model Commodore - VN-VP will not fit VR or VS. Also a VR will not fit a VS. The correct way is to read the I.D. sticker on the transmission bell housing....if your VS is a '95 model it will read 5HDD or a '96 VS it will read 6HDD etc. A statesman trans will fit as it should have the same I.D. unless it has the V8 motor. Just make sure the sticker is the same and you cannot go wrong.
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    Im not as knowledgeable as other holden nutters but to my knowledge none will. The manual transmissions apparently changed somewhere in the VS lineup and the autos are different as well (from memory) though i dont no the specifics. I could very well be wrong, please correct me if i am. But some more details about which series both cars are and type of transmission will help us help you
    ** Ooops damn satellite internet and its delay :P my bad
    VS
    Jul 2010
    Quote Originally Posted by hako View Post
    If no ID sticker is found, look on the passenger side, rear of the transmission, the back corner where sump meets transmission and it should have it stamped there.
    Vs Berlina Series 2
    Jun 2010
    cool cheers guys Also what do u think the problem will be if my trans clunks hard into drive jolts the whole car forward, i have no first, and engine warning light is on ??
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Start by getting a paper clip to read the codes and clunking is caused by 2 possible things 1 is low oil and 2 the bands for the gears may need adjusting even replacing in some circumstances
    few commodores
    Feb 2011
    victoria
    broken accumulator spring inside possibly? do a code check and see what errors it's throwing.
    no band adjustment as such on these trans (there is some adjustment by changing a certain pin to 1 of 3 options)
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by xcler8 View Post
    There is no ajustments for the bands nor do I think there are bands.
    few commodores
    Feb 2011
    victoria
    there's 1 band and it's tension for adjustment is controlled by the pin in the 2/4 servo assembly, but there's only 3 sizes available and is decided upon measurements taken when the trans is being built.
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    no vp has a kickdown cable an it's model is 4l60
    vr/vs don't have one as they're electronic an use the 4l60e
    Vs Berlina Series 2
    Jun 2010
    got error code 82, ( 1-2 shift solenoid "A" circuit)
    .. does any1 know if this can be replaced ?
    few commodores
    Feb 2011
    victoria
    sure can, it's fairly simple.
    get the right replacement solenoid for model trans, take the pan off (catch all the oil that's gonna come out), unplug the wiring from it, pop the retaining clip, pull out the solenoid... reverse order with new solenoid, while you're there it won't hurt to put a new filter in and refill with fresh fluid.
    Can do it in car without removing the trans...
    Vs Berlina Series 2
    Jun 2010
    cool cheers man
  1. [VIC] Swap- my vn-vp v8 trans for a vs v8 trans
    By Gunns VC in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2011, 08:01 PM
  2. wiil a 7hbd trans replace a 5hbd trans in a vs ss??
    By droppedpiez in forum Mace Engineering
    Last Post: 09-10-2010, 09:47 PM
  3. [NZ] l67 trans ecu and loom and subframe trade for 5l trans ecu,loom and subframe
    By Nzpure in forum Swap / Wanted to Buy / Trade
    Last Post: 21-04-2010, 09:51 AM
  4. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  5. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
