Results 1 to 4 of 4
Thread: VR transmission stuffed???
    vr 5.0
    Jan 2012
    moruya
    Default VR transmission stuffed???
    hi guys, i recently got a VR 5.0 litre and its all good except the transmission could be stuffed, for a start it has
    no reverse and when im driving i gotta give it a boot full to get it into second and im pretty sure ive only got 2nd and 3rd once its out of first. ive checked the error codes and 24(vehicle speed sensor fault) came up. ive also read something about being in "limp-home" mode. the car has been in a very minor front end bingle but only radiator support damage.
    any suggestions?
    Dec 2005
    is vehicle speed sensor fault related to perhaps the abs speed sensors? before i put my car to manual , i had no reverse, and it would also flare out when changing gears
    you should take it to an auto electrician who can check it in detail on the computer any other faults with the auto
    few commodores
    Feb 2011
    victoria
    few commodores
    Feb 2011
    victoria
    fix the speed sensor, the gear changes are all pcm controlled, if it thinks it's doing 0 km/h then it's not going to change speeds
    does the speedo work? have you tried resetting the ecu/pcm (disconnect the negative battery terminal for 30 second to a minute then reattach)?
  1. Cat stuffed?
    By Vp stocko in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2011, 05:15 PM
  2. Transmission stuffed after rebuild
    By levymetal in forum The Pub
    Last Post: 30-01-2010, 07:12 AM
  3. amp stuffed?
    By VY.abercrombie in forum Car Audio
    Last Post: 01-10-2009, 01:48 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. help! vk stuffed
    By claimingkatz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2006, 02:57 PM
