Results 1 to 12 of 12
Thread: Flat key, BCM Swap?
    VS Acclaim
    Oct 2011
    Crystal Brook
    Default Flat key, BCM Swap?
    The key on my VS acclaim is pretty much buggered, its weird, it will lock the car, but not unlock, and ive known its been on its way out for a while 'cos ive always had to get real close to the car. Anyway, i've heard that its about $160 to get a new key head? so i was thinking maybe if i can get hold of a new BCM with a good battery in the key and just swap them over, and it might be cheaper? and if so, whilst i was at it was thinking about getting a MID BCM, would this just plug and play into my VS that has a LOW? What advantages would it give me? ive installed power windows so maybe auto drivers down window? cheers for any help
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    You can get a new key head for 100bux max, why would you bother going threw all the hassle of a new bcm just for a new key,, is pointless an unnecessary.
    edit: you can only replace the bcm with the same level bcm that was removed,
    Signature Goes Here
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    I am going to replace the battery in my worn keyhead and see what happens .
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you replace the BCM you will usually get only one key head. If you just get a new key you will have a spare key.
    A MID BCM is the same as a LOW, but with the power window auto down and time out function. Hi and Lux BCMs from Berlina and up will not plug and play.
    Dec 2005
    VS Berlina/ KJ Verada
    Sep 2006
    Try eBay man, genuine holden keys @ $60. Take it to a locksmith to program it then unlock your car with the old key and put your newly programmed one in the ignition, start and go!
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Sep 2006
    Quote Originally Posted by James39 View Post
    Curious to see how you go. One of mine fell apart, I've been meaning to try it but I can't get the key shell to stay together, it keeps falling apart even with superglue.
    95 VS Berlina
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    yep mine died this week lucky I was at the shopping center and the locksmith there was open, cost me $108 for a 3 button keyhead with my key part fitted and programmed. was easy to get it working on the car, open car with key, start the car, don't touch anything for 2 mins. turn off car and restart all sorted.
    ========My Statesman 20's Mafless and 3.9's========
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    try using something like aroldite epoxy adheasive, stronger and more durable. any auto shop should have it in a 2 part tube form. just squeeze out a small amount of equal parts, mix and apply. let it go slightly tacky and then press together and clamp. once its cured it should hold together pretty nicely
    VS Acclaim
    Oct 2011
    Crystal Brook
    so a MID will plug and play with a low BCM? Cos i have installed power windows and auto down would be nice... also, if i got a BCM and key head with a boot button, would it be easy enough just to get and actuator out of a boot lid as well and put it in mine? cos my key head doesn't have a boot button at the moment, and i THINK my boot has the loom for it..
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by SWE11L View Post
    I have had them apart before, I used superglue not sure the brand now but it was the type that used a brush to apply the glue.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Linzi View Post
    I cant see any reason why it would'nt.
    It will need to come from a VS, as they are not backward compatable with VR.
  1. K&n flat panel air filter or ryco flat panel cant decide
    By meni469 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 09:57 PM
  2. How to run 14 flat in a VN/P 5 litre
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2010, 04:27 PM
  3. flat battery
    By Petes VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2009, 08:54 PM
  4. Flat key
    By younglion in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-05-2009, 08:20 PM
