Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By James39
Thread: VS cutting out, seems only when turning right.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Default VS cutting out, seems only when turning right.
    Hey guys just today my VS has started cutting out while turning. It only did it twice, at large intersections and while turning right.
    I'm hoping it's just that I had low fuel? The light wasn't on though, it was slightly above the line where it starts to beep at you.
    Anybody have any idea? Also, might help to say my power steering doesn't work I guess.
    V6 VR Acclaim
    Jun 2010
    Quick question: Are you trying to accelerate briskly when this happens? Sounds to me like the hose that goes from your swirl pot into the tank is not in the swirl pot anymore. Basically, what happens is the petrol goes to the left hand side of the tank when you turn right, obviously the faster you try to do it, the faster the petrol moves.. This causes the petrol to "fly" out of the pot and quite possibly miss the hose all together (If it's actually still in the correct positioning), ending up in you starving your engine of petrol.
    It's generally not a bad thing but make sure you try and keep your petrol supply a little more than almost empty, your fuel pump may burn itself out if you do not... Which is not a fun thing to have happen
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    ^^^^^^ This happened to me as well in my VR. Not hard to fix, just time consuming... But bourbon is correct.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Had a similar issue. Except i was told it was the baffle in the tank that was gone. I dont know cause i just changed tanks and gave the old one away.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    I don't floor it or anything, stays in the same gear the whole way and even did it right in front of cops haha, so yeah. That's what I thought, fuel moving due to inertia and whatnot. I'll have to top it up and see what happens, thanks guys
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Bourbonated View Post
    From what I understand it is the fuel return line in the tank that goes to the swirl pot
    Thanks Brett_jjj for the photo
    http://forums.justcommodores.com.au/member.php?u=61476
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by CLUBSPORT#325 View Post
    Fuel pump. Bad petrol
    If it happens turning right then it has SFA to do with fuel pump and bad petrol lol
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by frogsta View Post
    I've been using 95 octane
    Well the old VS was meant for 91.
    I get the same problem yet I use 98
    Jul 2010
    Wilton/Sydney
    i only use 98... I found that the car only did it when the tank was half full.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    I've got the mace memcal, and I assume this is just an 'amount of fuel' related problem...?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by James39 View Post
    Correct.
    The return fuel line is aimed at the bottom of the swirl pot and has a venturi at its end. As the returning fuel is squirted into the swirl pot inlet hole it creates a low pressure area that draws fuel from the bottom of the tank to keep the swirl pot full. The pump sits inside the swirl pot so has plenty of fuel around it's inlet regardless of tank level.
    I agree that the OP's issue is the swirl pot.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Thanks guys
  1. Accessories turning on by itself after turning car off
    By Danny40 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 11:04 AM
  2. subbs turning off ! cutting out.
    By mitchy_vn in forum Car Audio
    Last Post: 05-12-2010, 04:48 PM
  3. VS Berlina cutting out under power (only when Turning right)
    By Tim_Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2010, 06:24 PM
  4. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  5. VX a/c cutting out
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 10:24 PM
