Results 1 to 9 of 9
Thread: Handbrake beep
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Handbrake beep
    Hi Guys.
    My VS keeps consistently beeping the handbrake chime at me while driving and its driving me nuts.
    I am thinking some sort of switch is broken as the handbrake light doesn't appear on the cluster when I pull the handbrake.
    Does anyone know what to do, if it is the handbrake switch is there a work around besides replacing the switch.
    Thanks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Some times giving the switch a few flicks by hand may free it up. To stop the chime until you can fix the handbrake switch - take the chime out of the cluster.
    and 3 Dangerous non ABS VN's
    VY SS
    May 2011
    Auckland
    Just get under there and short the switch out. Wont chime even if it's on
    Jaymz's Avatar
    Jaymz is offline Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    My VS has the same problem. All i do is raise the handbrake up one click and it is all good. (the cable has some slack in it so it is safe to do so).
    Where is the switch located? I havent had a look, but am guessing it is under the lever under the centre console?
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
    Bux
    Bux is offline
    VL Calais
    Sep 2011
    Trafalgar Vic
    The switch is under the lever,in everything up to vn anyway. so i suppose vs the same. need to pull console out and clean out all the crumbs and crap that normally accumulate there. Its a yellow wire. I had my beeper going off but the light was still working, ended up being a broken line on the printed circuit part on the back of the cluster. Soldered that together and now seems ok.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Jaymz View Post
    Haha I have done the same thing. I would say my switch is dirty though considering I don't currently have a hand brake boot.
    few commodores
    Feb 2011
    victoria
    didn't they have this issue if the dash globe is blown/not contacting in the socket
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    could also lift up the cover where your t-bar/ashtray is and just inplug the wire. all its doing is earthing the circut when the lever is pulled up much the same as the boot light switch. worked for me
    few commodores
    Feb 2011
    victoria
    as he said the light isn't illuminating, double check the globe first, i'm sure the l3 clusters beep if this is he case, been a while since i've had to deal with it, might be the same issue
  1. How do I disconnect the warning beep for the handbrake?
    By kaz777cars in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2010, 07:47 PM
  2. stop that beep beep beep digital dash
    By murphy_51 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2010, 07:04 PM
  3. BEEP BEEP BEEP - Bulb sensor keeps going off
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2009, 03:28 PM
  4. Horns! beep beep ....
    By rcnugget in forum General
    Last Post: 05-11-2008, 09:10 AM
  5. beep beep bip bip bip
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2006, 07:06 PM
