Results 1 to 18 of 18
Thread: No power increase from sc14.
    vr calias
    Feb 2010
    Portland
    Default No power increase from sc14.
    I've installed a sc14 on my vr calias. I was in a bit of a rush and I started it up without a waste gate. I blew out the rocker cover gaskets. I changed them and it seems like there's no power increase from the charger at all.
    It seems to be leaking oil form the dip stick. But I'm not 100% sure. The oil light always comes in under boost.
    Has any one had any problems like this under boost?
    And what can I do to fix it??
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    sounds like your boost is going into your crankcase your going to have to change its setup likey cause will be the hose on TB
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah will of left the hose from TB to the intake base connected and be blowing all your boost straight into the crankcase and out anywhere it can go dipstick rocker covers rear main seal etc
    vr calias
    Feb 2010
    Portland
    Which hose? The vacum hose. I used the map senser vac line to run the waste gate. I didn't touch any hoses on the tb.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    there is a 12mm or bigger hose from a barb under the TB and it goes down onto the manifold base block the TB end and leave the hose on the manifold open
    vr calias
    Feb 2010
    Portland
    vr calias
    Feb 2010
    Portland
    Ok that seemed to have worked. But won't be sure to later. It still feels like its not all there
    в∞ѕтεכ √&
    Jul 2008
    NZ
    post some pics of your setup
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    You have had it ECU tuned, right?
    Ronald Reagan (1986)
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    really depends on your setup but a tune is a defenite to get any real benefit is it the stock pulley?
    vr calias
    Feb 2010
    Portland
    I haven't tuned it as of yet. Waiting till I get my comp extractors b4 I do that. I will post pics tomorrow.
    vr calias
    Feb 2010
    Portland
    VX Berlina
    Apr 2007
    Quote Originally Posted by sokana View Post
    Mate I'm definately no expert on superchargers or turbos but I'm going to venture a guess as to why its not giving that much extra go.
    The ECU has no idea as to how to act with all that extra air. The fact that it is running at all, is because the ECU is trying to compensate and chucking extra fuel in to match. But still it won't be perfect.
    There are many variables with the ECU, and timing and fuel delivery are some critical areas that need to be addressed when shoving extra air down your engines neck.
    I'm willing to bet that as soon as you get it tuned, it will feel 100% better.
    To be honest I wouldn't even be running it without the tune, except to get it to the tuner, and only if its running semi-decently, with no hint of pinging.
    If I'm wrong than someone with more knowledge should feel free to correct me.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    2psi wont hurt anything may just spit error codes for map sensor anything more needs a 2bar map sensor and injectors plus a tune.yes you can just fit a rising rate reg with say a 2:1 ratio and feed in more boost but its dodgy to say the least and will only keep it alive for so long with stock spark advance and cost you power in the end from being rich
  15. #15
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Why do people persist with these superchargers? Not trolling just genuinely curious. They are a cheap nasty thing. If your only going to putting in 2 psi what is the point?
  16. #16
    VX Berlina
    Apr 2007
    Quote Originally Posted by wraith View Post
    You answered yourself.
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can get them upto 12-14psi but generally they start desintergrating and just get too hot.iblown went fast with one but he said you could cook eggs on the inlet manifold like it was a BBQ LOL.the best place for them is the bin and fit a turbo in its place and go way better at lower boost levels
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by delcowizzid View Post
    Ah ok thanks delco. Sorry for derailment OP.
  1. to increase power
    By franks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 06:24 PM
  2. increase power in VH
    By ezy_4_u in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-09-2009, 11:04 AM
  3. [Buick] Want power increase from a sik as VN
    By Phat VN in forum V6 Development And Modification
    Last Post: 18-04-2009, 06:12 PM
  4. power increase
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 06:43 PM
  5. power increase from pod
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2006, 10:54 PM
Tags for this Thread
