Results 1 to 5 of 5
Thread: VR SS 5.0L troubles help needed asap
    1994 VR BT1 SS
    Oct 2011
    Tasmania
    Default VR SS 5.0L troubles help needed asap
    Just put motor & box back In VR SS 5.0L, have hooked everything up, put battery in went to kick her over. No dash lights, no cranking no nothing, however the headlights r coming on donuts DEFINETLY not a flat battery. I have checked everything & everything I can c is hooked up. Any suggestions would b great.
    VB SL/E
    Dec 2008
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    have you checked the engine fuse? could also be a missing earth somewhere
    1994 VR BT1 SS
    Oct 2011
    Tasmania
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by daza26 View Post
    Headlights coming on is no guarantee that the battery is OK. Battery may still not have enough charge to turn on dash lights and starter motor. Have you checked the battery charge with a multimeter when you turn on the ignition to try and start the car? Check the battery earth for a good connection to the body. Check the fusible links as well as the fuses and relays that others have suggested. Have you tried starting it with the gear selector in neutral as well as park?
  1. !!help needed asap!!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2009, 11:35 PM
  2. what t peice do i need? help needed asap
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2009, 07:36 AM
  3. Vs gearbox (help needed asap)
    By vs_lover in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 05:59 AM
  4. head unit wiring troubles need answers asap please
    By white vn ss in forum Car Audio
    Last Post: 03-11-2006, 07:41 PM
