Results 1 to 4 of 4
Thread: Door hinge and horn contact
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    Default Door hinge and horn contact
    Hi guys,got a score on a compleat wagon for spares. Now turning my Toyota in to a Holden..
    How do you remove the door hing pins, do you knock them towards the center of the door or outwards. Mine wont budge.
    I need to replace the horn contact pin on the steering column, How do you remove the housing that it sits into? Looks like its held on by the top column shaft brng.
    Thanks..
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Best advice I can give: invest in a car manual. Will tell you how to remove them.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Sep 2009
    Broome
    Worked out the horn contact. Remove 2 white plugs top and bot on the outer column. Remove C clip from column,rotate assy ccw and pull unit out. Getting the C clip back on with out the shaft going back down by yourself is fun. Door hinge? 9' cutoff wheel..
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    all I know is that you need a tool that can pull the pins out of the hinges and i think it uses the same concept as a dent puller.
  1. [VN-VP] How to Fix Steering Column Horn Contact VN Commodore
    By wortus in forum Holden Commodore How-To's
    Last Post: 12-01-2012, 11:18 AM
  2. VL door hinge pins?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-11-2009, 09:29 PM
  3. VS door hinge
    By cliffo78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 11:46 PM
  4. VN horn contact removal
    By redcane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2004, 12:52 PM
