Results 1 to 12 of 12
Thread: A/C issues
    1996 VS Statesman 5ltr
    Jan 2012
    Castlemaine
    Default A/C issues
    hey guys,
    of recent, my a/c compressor seems to be slowing down after about 30 seconds of being turned on, and by slowing down i mean it will do one full revolution to approx five full revolutions of the ac belt, and then stops blowing cool air, i have checked the belt tension, that is fine.
    the clutch is engaging correctly.
    Any help would be great!
    Thanks in advance
    few commodores
    Feb 2011
    victoria
    it's geared via the size of the pulleys it's not meant to be 1:1 per belt revolution
    if the compressor is turning less and you can see this and the engine rpm isn't changing then the clutch is slipping, either that is on it's way out or the compressor bearings are.....
    Jan 2012
    Castlemaine
    Thanks mate, yeah I didn't discribe it very well, the belt is spinning over the compressor pully, slipping as such...if bearings need replacing is that an easy job, can it b done? Of do I need to replace the whole compressor?
    few commodores
    Feb 2011
    victoria
    the clutch should be reasonably easy to replace without having to degas and remove the compressor as a first step to rule out a fault there....
    if it's the compressor at fault, i'd replace the compressor rather than mess about trying to reco it, would need to be degassed and regassed though, so maybe a job for an ac specialist.
    no nasty noises coming from it at all?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    before you go replacing things, check, with the a/c turned on, that you are getting over 12v to the clutch. might just be the voltage isn't high enough to pull the clutch in hard enough.
    vn commodore
    Jan 2012
    gosnells wa
    check the nut on the front of the a/c clutch as they some times work loose
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    i think what hes tryin to say is the belt moves but the pulley on the aircon doesnt. correct me if im wrong but thats how i read it
    few commodores
    Feb 2011
    victoria
    yeah aussie, that's about it, starts out fine then 30 seconds or so later slows down compared to the belt movement.
    Jan 2012
    Castlemaine
    Yeah Aussie and jxw, that's correct, the clutch is working, but almost as the the pulley is seizing up, nah no strange noise, apart from belt squeal.
    few commodores
    Feb 2011
    victoria
    with the engine off(you really don't want to lose fingers to the belt), can you easily turn the clutch/front of the compressor by hand? there will be some resistance but it should turn reasonably easy and not bind/grip to much. Not the pulley the belt is on.
    Jan 2012
    Castlemaine
    hey guys,
    yeah i can turn the centre part of the air con pulley by hand with little resistance, i have uploaded a short vid of this to show you what it is doing
    you will see on the video that the centre part of the pulley is stopping at one point, this is also the only point that it is showing any resistance when spinning by hand.
    5 ltr A/C compressor - YouTube
    few commodores
    Feb 2011
    victoria
    as wamboin said check the voltage at the wire/plug with the ac on, just strange that it works ok for 30 seconds and then slips.
    another thing to maybe try is unplug the clutch wire and run a wire straight to the battery +ve with the engine running, if it's a voltage problem a direct feed should engage it properly.
  1. Vs issues
    By PeeBody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2011, 02:02 AM
  2. just got an 86 VL ?? got issues man ...
    By crappyVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2010, 11:24 AM
  3. LPG issues
    By 85_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-10-2010, 11:28 AM
  4. Oil Issues
    By Speed16 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2010, 12:02 PM
  5. Issues
    By PhatVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2005, 09:19 PM
