Results 1 to 4 of 4
Thread: 95 VS radiator replacement!
    95 vs commodore series 2 executive
    Jan 2012
    vic
    Default 95 VS radiator replacement!
    i have a series 2 95 vs auto and am replacing my radiator. just thought id come on here and ask for some steps to take so if anyone can help itd be much appreciated! im a virgin at radiator replacements and car repairs in genral!
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Using the search function here might prove useful.
    http://forums.justcommodores.com.au/...sa.x=7&sa.y=11
    Very easy to remove though undo the top and bottom bottom hose clamps and the trans cooler lines if auto.. disconect the fan if a V6, then there are clips on each side that can be removed, then pull the radiator upwards..
    Oct 2011
    Quote Originally Posted by micka24 View Post
    first thing first is disconnect the bottom hose off the radiator (not the motor) let the fluid drain out then take the hose off the motor. then take the top hose off, unscrew the 2 gearbox lines and make sure they hang up unless you want auto trans fluid through you engine bay, disconnect the plug going from the fan and lift the power steering resiviour out then unscrew the 4bolts holding the fan in and lift it out. there are 2 clips on the side of the radiator i jimmy these out with a flat bladed screwdriver. also disconnect the overflow pipe from the side where you fill the radiator up. when you undo those clips on the side of the radiator it should just lift out easily. just when you replace the radiator make sure the 2 lugs on the bottom of the radiator sit in the holes in the frame..
    VB SL/E
    Dec 2008
    Don't forget to flush the system including the heater separate.
    Also check all the heater hoses and the thermostat bypass hose for replacement.
  1. Radiator replacement
    By SS Manual in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-06-2011, 03:40 PM
  2. radiator replacement
    By Cameron P in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2011, 09:05 AM
  3. Replacement Radiator Fan
    By Cobra30 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2010, 10:31 AM
  4. Radiator Replacement
    By Cursed CX8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2008, 04:04 PM
  5. VY Radiator replacement?
    By kricket in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-05-2006, 09:08 PM
