Results 1 to 2 of 2
Thread: average life of inlet manifold gasket? vs commodore
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default average life of inlet manifold gasket? vs commodore
    hi replaced my inlet manifold gaskets about 70 000 k's ago (had only 90 000 on teh clock) they looked like they saw better days anyway made heaps of difference in performance....ive been getting a rough idle for a while and replaced everything that could cause it etc.. Could i have a stuffed gasket again? theres no oil or water being lost well maybe a bit of oil but could just be a little leak. ive read if teh inlet gaskets stuffed u can get bad fuel econamy? but shouldnt i be looseing water to? if its stuffed
    thanks
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    the very first time i ever did inlet gaskets years ago, i put them in dry (i.e no sealant apart from the corners). these leaked within a few weeks. traces of oil in coolant & coolant in oil.
    Ever since, i've installed them with plenty of sealant around every port, every oil and coolant gallery. pretty much sealing all areas from each other. Ive never had issues since.
    That's how my experienced mechanic friend showed me to do it.
    note: by 'plenty' (of sealant) i mean enough to create a good seal. Not so much that it oozes great amounts out
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. Inlet Manifold (Gasket???)
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2012, 02:44 PM
  2. Head gasket or inlet manifold gasket? HELP!
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2011, 03:54 PM
  3. inlet manifold gasket for vt v6
    By jewel_aus_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2011, 03:31 PM
  4. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  5. inlet manifold gasket
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 11:33 PM
