Results 1 to 7 of 7
Thread: Rear demister - but not the fuse
    VS Executive
    Feb 2012
    Default Rear demister - but not the fuse
    Hey guys,
    Ive got a problem at the moment with my rear demister, it wont kick on at all, the button doesnt light up when engaged, fuse is ok, connections on the screen all look ok, im going to give it a full trace this weekend and see if i can find a problem, but just wondering is there any common things that cause the whole circuit not to work not related to the fuses that i should be looking for? Thanks in advance.
    VS 5 Litre BT1
    Jul 2006
    Could well be the switch in the dash. I had the same problem a few years ago and a new switch fixed it.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Faulty switch I reckon too.
    Visit my Facebook page
    VS Executive
    Feb 2012
    Cheers for all the info guys, I've checked the relay, i swapped it with another one that was the same, no change, def not just the LED in the switch cause the demister itself wasnt working a nice little frosty morn we just had. Ill check the switch first, will just pop it out and check if i can get a connection if i hardware the cables together.
    Cheers all. Muchly appreciated.
    VS Executive
    Feb 2012
    Hey All, just an update for those that gave me some advice, what the issue turned out to be was when i removed the switch there were two contact LED's that are quarter turn lock in, one had come loose and was just flopping about. Tightened it back up, was all good again. Easiest fix on a car i've ever had!!
  1. VT Rear Demister
    By Mirkz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2011, 01:30 PM
  2. rear demister
    By calay in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-06-2010, 04:09 PM
  3. Rear demister cause rear window to shatter?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 10:24 AM
  4. rear demister
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2008, 09:12 AM
  5. rear demister
    By stock_vl in forum Electrical Wiring / Questions
    Last Post: 19-08-2005, 10:37 PM
