Results 1 to 4 of 4
Thread: Clutch pedal very heavy
    VR 5.0 ute
    Jan 2012
    Default Clutch pedal very heavy
    Hi, I have a manual 5.0 V8 VR ute. The clutch pedal is incredibly hard to push in. The gear changes are fine, there's no odd sounds or rattling coming and no other problems that I can tell.
    What could be the cause of this? I've done some searching and it could be the clutch spring or clutch cable. I'm not 100% sure though. Any other problems it could be or any ideas on how to fix it?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I would say a worn or poorly lubricated cable.
    They do fail after a while so i would just replace it and see if it improves.
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    if you have just bought the car or its always been like it it could simply be just a heavy duty clutch my old t5 Wagon had a Exedy heavy duty in it and that was stiff as ev en with a new cable
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    VR 5.0 ute
    Jan 2012
    Cheers for the replies fellas. I'll check out the clutch cable. I wish it was just a heavy clutch but the car is almost undrivable due to the pedal. It takes a lot of force to push it in.
  1. heavy duty clutch??? VR V6 94 UTE??
    By kwak_pipe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 02:45 PM
  2. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  3. Heavy Clutch
    By caekmaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2008, 03:07 PM
  4. rpm heavy duty clutch
    By 5speedcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2006, 01:10 PM
  5. Heavy Duty Clutch For T5?
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2004, 07:09 PM
