Results 1 to 4 of 4
Thread: Electrickle
    VS Executive
    Dec 2011
    Mt Gambier
    Default Electrickle
    Howdy,
    I discovered that my fuel pump power lead (the four pin jobby that plugs into the fuel tank assembly) isn't connecting properly.
    With the relay bridged, so it gets power all the time, I can turn the pump on by pressing the left (earthing?) side of the plug.
    It's very, very touchy...moving the lead around or simply touching the clip will invoke the pump.
    I cleaned it up as best I could and bent the left pin a bit...seems to have helped but I need to fix it properly.
    Someone told me about an spray to help electrical connections...should I try that???
    Should I keep trying to bend the pins or just buy a s/h FP assembly from the wreckers? - which I don't really want to do.
    The blue rubber dust cover fing is present and seems okay...I get the impression this aids location and snugness of fit?
    Any ideas greatly appreciated...cheers.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just bend the pins until all connections are tight.
    Visit my Facebook page
    VS Executive
    Dec 2011
    Mt Gambier
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    would be better to retension the pins in the plug. there should be a spring part in there.
    it won't be the fuel pump side, it will be the car side.
