Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By troykinsvt
Thread: I need/want custom roof lining
    VS Equipe s2 slammed
    Feb 2012
    Narara,NSW
    Default I need/want custom roof lining
    Where can I get custom roof lining ?
    few commodores
    Feb 2011
    victoria
    VS S Pack
    Sep 2009
    all depends on what you mean by custom, different colour or a pattern imbossed
    If just a different colour try a motor trimmer there is a guy in Wyong that does good work - not sure how much he would charge as I just got the material off him
    There is a mobile guy getting around the coast as well sorry cannot remember the name on his van
    If you want an imbossed one I would still try a good auto trimmer bit you might need to look for someone in Newcastle or Sydney
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Easy enough to do, just time, patience and some material. Much more satisfying doing it urself. Plus hella of a lot cheaper.
    VZ MY06 executive 3.6L
    Feb 2012
    if your just changing the material, i went to spotlight and chose a blue swade material 148cm wide x 2m long, clark rubber for 6mm thick foam ( couldnt get same width so i got 4m worth) and autobarn for spray on vinyl adhesive (2 cans)
    all up it cost me around $100 and 3 hours (with a carton of crowns).
    start off by taking ur review mirror off, roof handles, sun visors, interior light and start taking one end of the roof down first,
    lay the front seats all the way back coz they will get in the way, once you bring the roof down take it out through the front door (it'll be a squeez) but youll get it,
    lay the cardboard on the floor and scrape off all the old foam with a scraper and wire brush, once it's clean get your foam ready and spray both the foam and the board with adhesive,
    wait for five mins the roll the foam out onto it? best to use a paint roller or something to make sure it's smoothes out properly, once the board is covered with foam give the foam and the material a spray with adheasive and wait for it to be tacky, DO NOT spay alot on the material otherwise it will distort the side you will see when it's done. lay it out and use the roller to roll it into the grooves.
    take your time with it as you dont want the material to crease when smooting it out coz it's hard to fix up, and make sure you leave some material over lapping the edges so you can fold it over to the other side,
    once you have done that let it dry for a while then get a stanley knife and scissors and cut out the holes so you can intall the handles and mirror ect once you put it back in.
    put it in the same way you got it out, try and get a mate to help you, then fold the door seals and strippng back on the edges and there you have it, new roof..
    id put pics up on here but i cant figure out how to make them smaller for it to work. hope this helps yas
    I live my life a corner at a time
    Demonica's Avatar
    Demonica is offline Mrs Wraith
    VS clubby
    Mar 2010
    SE Qld
    I did a custom job on my old VS ute. Had this idea about the whole decoupage thing that some people do for boxes etc. So bought a bunch of shirts with skulls, cars, devils etc on them, ripped the original material off the lining, sealed it then cut out the pics and wanted and glued em all on. Was then just a matter of few coats of varnish, quick sand then repeat until the whole thing looks like 1 big artwork and you cant feel lines. Turned out friggin awesome
    troykinsvt's Avatar
    troykinsvt is offline yes i like fibreglassing
    VT
    Oct 2011
    helensvale
    i got a custom one made , all i had to do was take i out , get a 10mm thick piece of foam and cut my design out so all the fella did was glue and stitch, first design was a flame covering half so it was 3d, cost 120 to do, sold it for $310 one im in the middle of doing is a skull
    stroking is fine but id rather be blown
    Demonica's Avatar
    VS clubby
    Mar 2010
    SE Qld
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    i havent got anypics of the flame but google flame roof lining and it should be the first pic ....a guy named VRTIDY did it in street commodores thats where i got the idea, but went from drivers side to passengers side (wide) and front to about 3/4 the way back , the skulls are in about the 4th remake its hard to get detail......in foam
    Demonica's Avatar
    VS clubby
    Mar 2010
    SE Qld
    That looks epic!!!!! I am surprised more people dont get into the whole custom roof lining thing. Although I didnt realise there was money to be made so I might have to buy a few and have a play around to see what I can achieve. Wouldnt mind something like thing for my beast though maybe something a lil more subtle than green lol
    If at first you don't succeed, destroy all evidence that you tried
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    thats almost spot on , pull the door sides down 3/4 and its very similar....
    Demonica's Avatar
    VS clubby
    Mar 2010
    SE Qld
    Keen for pics of the skull one when you're done. Do you actually put them in your car or just doing them now to sell? My apologies for hyjacking the thread Blake95 btw
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    put them in my car it looks puuuurdy
    Demonica's Avatar
    VS clubby
    Mar 2010
    SE Qld
    Quote Originally Posted by troykinsvt View Post
    Pics dammit lol :P
  1. VS Roof lining
    By vsv8berlinawag in forum General Discussion
    Last Post: 02-04-2012, 08:55 PM
  2. Roof lining
    By ShawtyNate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2011, 05:39 PM
  3. VT Roof Lining
    By CommieKal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-10-2010, 08:48 PM
  4. [SA] FS: Complete VQ Roof Lining + Caprice Roof Bits
    By PREDATR in forum Parts And Other Items For Sale
    Last Post: 21-07-2009, 06:10 PM
  5. VR Roof Lining
    By YByN8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 08:50 PM
