If its LSD then yes otherwise no. IRS means Independent Rear Suspension.
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
What your confusing it with is an open diff vs. LSD (limited slip differential)
Internal Revenue Service? :/
There is no such thing as stupid questions, Only stupid people.
I <3 this place
internal rectum slip
i loled at this.i thought this was a "ve 4 lyf" thread,(sadly puts away troll mask)
Sorry guys I wasnt sure if it had any effect on how the wheels spun. How do I know if it's LSD?
just jump on the brake and see how many black lines you leave behind you
Look for a tag hanging from the diff filler plug that says 'LSD'???
hahahahaha. give the guy a brake. there was once a a time when we all didnt know the difference. its a ballsy question to ask.
if none spin the handbrake is on or your still in gear
most cars will leave 2, the front tends to lock before the back
You could just jack up one wheel and if it is stiff to turn it's LSD, if not it's an open (or a shagged LSD). Trans in neutral and handbrake off.
Make sure the car is on level ground, chock the wheels and use a jack stand.
The wheels on the bus go round and round.....
Originally Posted by Reaper:
Originally Posted by Jecs:
Two black lines= LSD
