Results 1 to 10 of 10
Thread: VS Ute Fuel Pump
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Exclamation VS Ute Fuel Pump
    I have been having a bit of trouble getting my ute to start, it just cranks over and over and after reading a few threads on here I thought I would change the fuel pump but have been told to do this I will have to remove my canopy and then the plastic liner so as to get at the pump itself, Does this sound right?, and also is it a hard job?.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Do yourself a favour mate check for error codes first it`s not hard abit of reading.
    Checking error codes VR/VS (Revised)
    When was the last time you changed your fuel filter?
    One of the ute owners will have to fill in the rest.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    from memory to get the pump out you have to yeah move everything.
    get that panel off from in the tub.
    and remove the tank itself.
    so it may be handy to get the fuel fairly low before you change it.
    just out of curiosity, do you hear a constant high pitched noise from the pump?
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    check for removable panels behind the drivers seat in the rear cabin , have you tested the fuel pressure yet ? exclude all the easy options first before accesses the tank area .
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Cheer's I will check out the extra things you guys have mentioned, it's strange because it wont turn over no matter what I do but if left alone, overnight type thing it does fire up but if I then turn it back off it's back to nothing?...
    1999 vs ute series 3
    Oct 2009
    remove the fuel line from the motor and crank it. If it squirts fuel at you then fuel pump should be fine
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    VL group A Brock
    May 2006
    Im having same troubles, the fuel pump works sometimes, then nothing, mate Im pretty sure its my fuel pump but just trying to get it out of the tank is a pain, I spent an hour today trying every direction I could to get it out but theres a black hose connected and cant get the thing to budge.
    VY S V6 Ute Series II 2004
    Nov 2009
    So.... when you do get it to start in the morning it keeps running without any problems?
    Is that right?
    Its when you switch it off again and then try to restart.... that's when it won't fire up?
    2000 VS III V6 ute
    Jan 2012
    Kapooka NSW
    In the Max Ellery repair manual it states the fuel filter is. On vehicles with IRS on the body forward of the fuel tank. On vehicles with normal axles its bolted to the floor pan in front of the rear axle. And on utes its at the rear of the fuel tank. Hope this is some help the manual doe not state to dismantle the back of the ute.
  1. VS commodore CAS or Fuel Pump? Fuel pump new BUT not priming on accessories
    By robert422 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 08:14 AM
  2. Replacing LS1 One Tonner fuel pump. Will std SS pump fit
    By chevy_big_block_bro in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-01-2012, 07:47 AM
  3. Fuel sender, after changing fuel pump. Question that has not been answered.
    By seq4x4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2011, 03:24 PM
  4. [NSW] Twin billet fuel pump holder for all BOSCH 040 044 pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 20-01-2011, 08:42 PM
  5. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
