Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 135
Like Tree2Likes
Thread: VS Berlina 1995 V6 4spd Auto...stalling issue!! :(
    Holden VS Berlina 3.8
    Jan 2012
    Penrith, NSW, Australia
    Default VS Berlina 1995 V6 4spd Auto...stalling issue!! :(
    Hi two days ago i got mi car back from the mechanics that suppolsvly fixed the stalling issue...now today while i was driving my family around the car stalls while im driving...i changed the harmonic balancer and teh crank angle sensor...changed the fuel pump and the filter what else could be wrong?!
    luv_mi_96_vs is offline Banned
    93 vr wagon
    Jan 2012
    dubbo
    Could be the injectors I've just been having the same problem but looks like the filter fixed it, check for code errors
    Jan 2012
    Quote Originally Posted by luv_mi_96_vs View Post
    Mate would have no idea how to check em i just get it serviced ,fill up petrol and drive
    93 vr wagon
    Jan 2012
    dubbo
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Here mate abit of reading but it is easy as you will be able to do it just read carefully.
    Checking error codes VR/VS (Revised)
    Quote Originally Posted by daora View Post
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Jan 2012
    Quote Originally Posted by VS_Pete_1 View Post
    after reading the instructions it seems confusing
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    Easy mate - just need a paper clip, bend it out in the shape of a big U then put each end in #5 & #6, so basically side by side.
    If you open you open your door and look under the steering wheel then follow to the bottom of the dash, the connector will be there.
    As soon as that is done, turn your ignition on and watch the engine light flash.
    Use that link to follow what code it spits out... Let us no how you go mate
    Jan 2012
    Quote Originally Posted by Fenix_Longbow View Post
    im gonna take the car to aanother garage this week so far i spent $831 on repairs on this car
    VS_Pete_1's Avatar
    Dec 2007
    Like Fenix_Longbow posted easy as you can do it mate..
    Just remember it will flash 3 times.
    1 flash/2 flashes = 12
    error code is ok.
    then it might go
    1 flash/3 flashes = 13
    so error code 13 may be your problem.
    VS_Pete_1's Avatar
    Dec 2007
    Mate I was scared to do it then when I did I said to myself you girl you will be right mate.
    VS_Pete_1's Avatar
    Dec 2007
    I just spent $600 and $500 coming up and that is cheap.
    Owning a car aren`t cheap
    Mar 2004
    Daora
    If you just had the car at the Mechanic, take it back and calmly explain what happened, I would be surpised if they dont want to help.
    If you have been reading this forum long, then you would realise that when a fault occurs, it "should" log a fault code in the cars computer, but this does not always happen, leaving the mechanic little to go by, other than your description of the problem.
    I had a similar intermittant fault that was difficult to find, ended up being the DFI module (under the coil packs) if you know someone with an old commodore, then borrow the DFI/Coil pack for a week and see if the problem goes away. It is very easy to remove and replace.
    Jan 2012
    Quote Originally Posted by 9C1pack View Post
    Daora
    I remember correctly they installed a 2nd hand DFI module they said they were "testing it"....other than the DFI module what else could be wrong? spark leads?
    Mar 2004
    Plug leads mainly play up under load (up a steep hill or towing). so I would htink if they were that buggered it would not run at all.
    Has the IAC (Idle Air Control) been replaced? (It's a little motor that controls the idle)
  15. #15
    93 vr wagon
    Jan 2012
    dubbo
    I just checked for errors on my car and it was easy as, should give it ago only problem is with mine system check came back fine and my car is still cutting out
  16. #16
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
  17. #17
    Jan 2012
    Quote Originally Posted by xcler8 View Post
    Check injectors and fuel pump
    Fuel pump has been replaced last week...im taking back to the mechanics tomorrow morning to fix the issue i spent $831 and it still stalling?
  18. #18
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    my mum had this problem. she had the fuel pump replaced twice and it turned out to be sand in the tank. did they clean out the tank when they changed the fuel pump? also does it splutter and then die or is it just like its running one min and then the next its gone?
  19. #19
    Jan 2012
    Quote Originally Posted by aussie4life11 View Post
    While im driving the car decides to turn of i had to put mi hazziz pull over waited a bit then turned the car on again i did it like many times it nearly caused many accidents grr some mechanics are so darn lazy they dont go straight to the darn point....i wish i knew how to fix cars that way i could've fixed it miself .
  20. #20
    Ghost's Avatar
    Sep 2011
  21. #21
    Oct 2011
    wat does it sound like to u heath? electrical or fuel? does it splutter at all and jerk around or does it just die and start slowing down?
  22. #22
    Ghost's Avatar
    Sep 2011
  23. #23
    Oct 2011
    yea could be that. but like i said we went thru 2 new pumps b4 the mechanic noticed soil in the tank
  24. #24
    Ghost's Avatar
    Sep 2011
  25. #25
    Jan 2012
    The mechanic said they installed a 2nd hand DFI module could that be the main cause? they alread replaced hte pump, crank angle sensor, harmonic balancer, major service....but they didnt change hte leads, rocker cover needs fixing the vally gasket needs replacing soon..man my ca has so many issues since i bought it of that guy
  1. VZ Commodore 4Spd Auto Thud Sound
    By extremeaudiowa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2010, 01:41 PM
  2. 1995 VS Auto V6 Radiator Issue
    By ETH4N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2010, 11:53 AM
  3. 1995 VS Berlina 3.8 Auto-First Car
    By Hodz91 in forum VR - VS
    Last Post: 14-02-2009, 11:17 PM
  4. VS 4spd Auto
    By Jecs in forum Parts And Other Items For Sale
    Last Post: 01-05-2008, 08:48 PM
