Results 1 to 10 of 10
Thread: Tailshaft issues
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Tailshaft issues
    Hi Guys.
    around a week ago I had the uni joints & center bearing changed on my VS due to the bearing being on its way out and the uni's had a fair bit of play in them.
    There was a little bit of vibration from the bearing before the change but not really noticeable.
    Since the mechanic swapped the uni's and bearing over the whole car violently shakes from the rear end/tail shaft on light throttle, when I am up to speed its not as bad but its the worst during take off......also seems to get a bit better once the car has warmed up aswel
    This has only happened since I left the mechanic after picking up the car so I took it back and he put it up on the hoist and said the shaft appeared to be aligned properly and there was nothing noticeable and to give it 100km or so for it to run in and settle .
    I have now done 500km and its slightly better but not by much?
    Anyone know whats causing this, I will be taking it back to the mechanic again but don't want to go in without any knowledge on what could be causing the problem
    The only thing i can think of is he didn't mark the tailshaft when he took it apart and it didn't go back the right way
    Thanks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Take it back.
    I would say the front and rear shafts are out of 'phase', meaning he didn't mark it.
    few commodores
    Feb 2011
    victoria
    yeah sounds like a phasing issue, i've never had to "wait for it to settle in" on any tail shaft i have ever done.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    did the spacers get put back correctly on the centre bearing ? was the front and rear shafts marked before being removed , could be the B angle and the phasing of the shafts
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Another for phasing, if he changes them and it doesn't help, u'll be up for a balance ~$100
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Another thing may be the new uni's weren't centred when they were installed. (giving the yoke a sharp crack with a hammer)
    VS Stato l67
    Mar 2009
    Melb
    Id be guessing phasing too. Get him to have it inspected by a driveshaft specialist if he cant fix it. The advice of giving it a while to "settle down" is rubbish. Tailshafts don't rebalance themselves and if its vibrating as bad as you say you can cause damage to the rest of the driveline by continuing to drive it
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive had similar stuff happen. I had bad vibrations coming from the rear of the car after Id had tailshaft disconnected from the diff. I fixed it by removing the tailshaft from the diff again, rotating the tailshaft 180 degrees, and then reconnecting it again. You wouldnt think that this could upset the balance of the tailshaft that much, but it does, it makes it vibrate pretty bad actually, after Id rotated it, it ran heaps smooth again and was back to normal..
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    From memory the yolk on each end of the tail shaft should be 90deg from each other
    VS Equipe
    Jan 2011
    Adelaide, SA
    Well he said he is certain it was marked and put back the same way
    Quote Originally Posted by Brett_jjj View Post
    Thanks, might give it a try on the weekend
  1. Is the vx v6 tailshaft the same as the Gen3 tailshaft ?
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2011, 11:48 PM
  2. VR Tailshaft issues
    By musicmandaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 12:27 PM
  3. Tailshaft issues
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2008, 07:47 PM
  4. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  5. Tailshaft Issues
    By vnvkuserabuser in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2005, 12:35 PM
