Results 1 to 5 of 5
Thread: electrical
    VR 5.0l ute
    Dec 2011
    penrith
    Question electrical
    hi all,
    Got issue (obviously). Brake light works without headlight.. Turn headlight on and its a permanent brake light.
    Was thinking corrosion in the bayonet fitting?? anyone else had the same issues??
    Thanks in advance
    Brian
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    Possibly. Sounds more like a wire is earthed out or crossed with another... Inspect the bulbs first
    VR 5.0l ute
    Dec 2011
    penrith
    yeah i have put new bulbs in already, seem to recall a bit of corrosion in the bayonette fittings.. but was not what i would call
    severe. My old hilux ones were nearly welded with rust and still worked when i replaced them...
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Sounds like an Earthing issue to me...
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Dual filament globes fitted the correct way around?
  1. VP Ute Electrical Help
    By mellowboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2011, 10:08 PM
  2. Electrical bug
    By vsdeath in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2009, 06:30 PM
  3. vk what the (electrical)
    By old55 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-03-2006, 10:12 AM
  4. vl electrical
    By basterdvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2005, 11:51 PM
  5. electrical
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2004, 07:26 PM
