Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By ephect
Thread: vs coolant temp sensor ?
    Vs Berlina Series 2
    Jun 2010
    Default vs coolant temp sensor ?
    just wondering if a faulty vs coolant temp sensor is a common fault ? pulled out of driveway last night got down the road and engine temp peaking to hot and started beeping and stuff so i pulled over popped the bonnet undid radiator cap wasnt hot check top and bottom hose they werent hot... put cap back on and drop away again and it was fine for the rest of the night ?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Fairly common problem. It's just age. Not that hard to replace. Nor is it an expensive part.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    There's 2 sensors on the vs, one for the gauge, the other is for the ecu
    It'll be the single wired sensor.
    Vs Berlina Series 2
    Jun 2010
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Here
    The one with the black wire.
    Coolant Temp Sender.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    As Pete posted,
    Gauge sensor is below the thermostat housing on the front
    Ecu sensor is at the back of the thermostat housing
    VS_Pete_1's Avatar
    Dec 2007
    Sorry no it is the shiny one so I would say the side of the thermostat housing lol.
    I know because I put it in and took pic.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Yes correction, meant below the hose connector on the thermostat housing
    As u elegantly put it, the side
    Vs Berlina Series 2
    Jun 2010
    where is the other one cant seem to find it ? i bought a coolant temp sensor and its fairly bulky sensor
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Did you get the Sensor or the Sender? I think they were referring to the Sender and not the sensor. The Sender is the one with a single wire coming off it in the Thermo stat housing.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by W8INL9 View Post
    Bad idea.
    I know it wasn't hot, but not a good habit to get into.
    A hot engine will instantly boil and throw boiling water out of the filler neck.
  1. Where is the water temp sensor located on 98 vt ???? (not coolant temp sensor)
    By 13thomo13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 10:19 AM
  2. Coolant temp sensor?
    By Jamie-b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2009, 06:24 AM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. where is the coolant temp sensor?
    By 300zx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2008, 11:01 PM
  5. Coolant temp sensor
    By v8bike in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2005, 08:05 PM
