I have a problem with my V6 wagon and I amwondering if anyone else has had the same issue.The engine just cuts out when I am driving along or when I come to a stop at traffic lights.It cranks over and starts straight away. Fuel pump was only replaced a month ago.Pulled the fuel filter out yesterday and that was fine,not blocked and replaced the crank angle sensor but that didnt help either.Any help would be great
Have you checked your error codes? It could me many things.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
Its not throwing any codes
check the plug that goes to the DFI module as poor connection s on this will cause similar
Could also be the IAC, TPS or cam angle sensor
But I would clean the IAC and check the DFI plug first
Did you do the pump your self, if so how did you go getting it out with that black hose, im having trouble.
No was done at a workshop. They are going to put a genuine pump in and see if that fixes the problem as it seems there is not enough pressure being produced
Problem seems to be fixed. Drove from minchinbury to the airport and back this morning and didnt have a problem
